It is currently Mon Mar 10, 2025 2:04 am
 Post subject: Bracing chisel uk
PostPosted: Sun Apr 12, 2015 3:28 pm
Hi
Can anyone recommend a good place to buy a curved bracing chisel in uk.
Dont want to spend to more than £20 really
 Post subject: Re: Bracing chisel uk
PostPosted: Sun Apr 12, 2015 3:32 pm
Last Name: Jeffries
City: Williamstown
State: NJ
Zip/Postal Code: 08094
Instead of shelling out a lot of money, all I did was just put one of my Marples into a vice and bent it to my liking. Works like a charm.
PostPosted: Sun Apr 12, 2015 3:34 pm
Jeff
Was wondering if that was a possibility. .. thought because its hardened it might shatter
What size chisel was it
Cheers :)
PostPosted: Sun Apr 12, 2015 3:46 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
You don't need a curved chisel to carve braces, just flip a bench chisel over to carve the scallops.
Have a look at this. https://www.youtube.com/watch?v=Lz-2OL_b-oU
Cal
PostPosted: Sun Apr 12, 2015 4:02 pm
Cal
Hey Cal
Good video cheers
But do want curved chisel as i think it will make it easier to carve the shapes .. especially the concave parts of the bracing
PostPosted: Sun Apr 12, 2015 4:19 pm
Country: Ireland
I think Axminster have them
These users thanked the author mike-p for the post: Cablepuller (Mon Apr 13, 2015 2:20 am)
PostPosted: Sun Apr 12, 2015 4:20 pm
First name: Rusty
You can also take an oxy-acetylene torch to it wherever you want the bend, it will bend like butter. Just make sure you keep the torch away from the sharp end of the chisel.
These users thanked the author RustySP for the post: Cablepuller (Mon Apr 13, 2015 2:20 am)
PostPosted: Sun Apr 12, 2015 4:46 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I purchased a curved chisel but do not use it, the upside down chisel like in the Martin video works way better. I radiused the corners so it does not damage the top if it slips.
Fred
Fred Tellier
These users thanked the author Fred Tellier for the post: Cablepuller (Mon Apr 13, 2015 2:20 am)
PostPosted: Sun Apr 12, 2015 4:48 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
I know you said twenty quids, and uk but I can't help to head you to wilco flier's chisels : http://wilcoflier-toolworks.blogspot.pt ... isels.html
50 eur and in the nederlands. Really high quality stuff, and made to your specs. Recommended.
Anyway, just an heads up.
These users thanked the author mqbernardo for the post: Cablepuller (Mon Apr 13, 2015 2:20 am)
PostPosted: Sun Apr 12, 2015 6:17 pm
I did too. Sort of on accident at first, but then I just went with it!
These users thanked the author Pmaj7 for the post: Cablepuller (Mon Apr 13, 2015 2:20 am)
PostPosted: Sun Apr 12, 2015 6:26 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
There is no way on earth you can heat a chisel sufficiently to bend it without the heat destroying the temper at the edge. Actually, you will ruin the temper long before the chisel gets hot enough to bend.
After the chisel has been bent to shape, you can , of course, re-temper the edge if you know what you are doing.
PostPosted: Sun Apr 12, 2015 9:08 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Yes it looks as though a curved chisel would work better for scalloping braces, but.... it really doesn't work any better than a regular bench chisel. You will find in order to cut the scallop (concave area) you will have to work from either side toward the middle of the brace with either style of chisel. I find that I can control the cut much better with the bevel reversed than with it upright. I think most would find the same.
But if you want to spend more money..... go for it.
Cal
These users thanked the author Cal Maier for the post: Cablepuller (Mon Apr 13, 2015 2:21 am)
PostPosted: Sun Apr 12, 2015 9:55 pm
City: Vancouver
Upside down chisel for me too.
These users thanked the author meddlingfool for the post: Cablepuller (Mon Apr 13, 2015 2:21 am)
PostPosted: Sun Apr 12, 2015 10:31 pm
First name: Rusty
There is a way and I have done it exactly like I stated. If there was any harm done at all it was not even noticeable and by the way it was a Northern Tools crappy China chisel so who cares anyway since it is a very seldom used tool but still it does the job. Having said this, I wouldn't modify a pricey tool like this, there are too many cheap tools out there to experiment with.
These users thanked the author RustySP for the post: Cablepuller (Mon Apr 13, 2015 2:22 am)
PostPosted: Mon Apr 13, 2015 1:16 am
First name: Lee
Last Name: Passmoor
City: Newport Pagnell
State: Bucks
Zip/Postal Code: MK16 8JG
Country: United Kingdom
Hi Cablepuller,
I bought the Two Cherries curved chisels from Axminster, thinking as you are to use them for braces, but I never do! Like everyone else it is an upside down regular chisel or a veritas palm plane
These users thanked the author flounder for the post: Cablepuller (Mon Apr 13, 2015 2:22 am)
PostPosted: Mon Apr 13, 2015 7:17 am
First name: Jim
Last Name: Kirby
This verges on religious discussion laughing6-hehe
Both ways work (curved chisel, upside down bench chisel) I tend to lean towards the curved chisel. There, I've weighed in with my vote on a choice that has no right answer. beehive
(or, I should have said, two right answers)
Jim Kirby
kirby@udel.edu
These users thanked the author Jim Kirby for the post: Cablepuller (Mon Apr 13, 2015 12:18 pm)
PostPosted: Mon Apr 13, 2015 7:33 am
OK, I'll throw in my $0.02. If you're so strapped for cash, save yourself a tenner and get a set of these - prep them as he shows.
https://www.youtube.com/watch?v=Ki8tt-VjwqI
These users thanked the author Colin North for the post: Cablepuller (Mon Apr 13, 2015 12:22 pm)
PostPosted: Mon Apr 13, 2015 7:42 am
I bought a set of those chisels. Turned one into a belly chisel. They are a bit crude but who cares about the 'lands' when it's not important? The steel seems perfectly good to me.
PostPosted: Mon Apr 13, 2015 9:29 am
Nice common sense approach in that video. For the OP's £20 should be able to get some decent chisels and everything needed to sharpen them well enough to do the job [:Y:]
PostPosted: Mon Apr 13, 2015 7:01 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Saw a video of Dana Bourgois (sp??) voicing a top, and he used a curved chisel and a small finger plane, but he used the chisel upside down - best of both worlds?
Ed
These users thanked the author Ruby50 for the post: Cablepuller (Tue Apr 14, 2015 8:26 am)
PostPosted: Tue Apr 14, 2015 2:50 pm
This is not a good idea. With heat you'll ruin the temper and the blade won't stay sharp. You can put the temper back in it but it will take you considerable learning and expense to master the process. If it were easy everyone throughout history would be Smiths equal to the Samauri but they're not.
Also when you heat metal you alter the chemical structure of it and weaken it. Best to do it once and leave it alone.
-j
PostPosted: Tue Apr 14, 2015 3:02 pm
First name: Rusty
Listen, you are are over thinking this a bit. I don't pour buckets of heat on a chisel, I put a very small, very hot flame a good distance from the edge such that the edge doesn't change color. I'm not a sword maker but my day job is metal working.
These users thanked the author RustySP for the post: Glenn_Aycock (Thu May 21, 2015 8:00 pm)
PostPosted: Tue Apr 14, 2015 4:14 pm
oops_sign
Sorry, couldn't resist it.
PostPosted: Tue Apr 14, 2015 8:42 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
"Saw a video of Dana Bourgois (sp??) voicing a top, and he used a curved chisel and a small finger plane, but he used the chisel upside down"
My point exactly. Why not use your money to buy a small finger plane - You'll get a lot more use out of that than you will out of a curved chisel (unless you don't own any chisels yet.)
Cal
These users thanked the author Cal Maier for the post: Cablepuller (Wed Apr 15, 2015 12:43 am)
PostPosted: Wed Apr 15, 2015 8:00 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
If you can make a curved chisel like this out of a flat chisel without overheating the edge, you are a better man than I ... and if you made a Youtube video of the process it would go viral in no time ...
Users browsing this forum: No registered users and 50 guests
